taddvs
(Taddvs)
July 16, 2020, 8:17pm
1
Starting today I seem to be having an issue with rhino starting up.
Rhino 6 currently will only start in safe mode. Tried disabling rhino render plugin and it still gets stuck at Preparing Viewports.
Rhino WIP was having the same issue until I disabled rhino render then it would load. Once it opens and I can load rhino render, it opens fine after that.
Tried rolling back the most recent geforce driver, the 2 most recent windows updates and still the same problem. Also tried 6.28, uninstalling both 6 and 7 wip and still the same issue.
pascal
(Pascal Golay)
July 16, 2020, 8:38pm
2
Hello -
Please run the SystemInfo command in Rhino and copy/paste the results here.
taddvs
(Taddvs)
July 16, 2020, 8:50pm
3
Hi Pascal
Rhino 6 SR28 2020-7-14 (Rhino 6, 6.28.20196.14041, Git hash:master @ e2d998688892dc5d110951546517e1de61ff35b5)
License type: Educational, build 2020-07-14
License details: Cloud Zoo. In use by: tad davis ()
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: DESKTOP-6JFIVD2
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 6-21-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.48
OpenGL Settings
Safe mode: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 6-21-2020
Driver Version: 27.21.14.5148
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 11 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp âCommandsâ 6.28.20196.14041
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 6.28.20196.14041
pascal
(Pascal Golay)
July 16, 2020, 8:58pm
4
Hm - this makes me just a little suspicious - you might try a clean -reinstall of the driver and see if that changes anythingâŚ
taddvs
(Taddvs)
July 16, 2020, 9:02pm
5
Hereâs the info from 7 wip that I can get open.
Rhino 7 SR0 2020-7-14 (Public Build, 7.0.20196.12025, Git hash:master @ 65b868f438ca0c24222b42aa3cdc3e9e93893384)
Expires on: 2020-08-28
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Z-Buffer depth: 24 bits
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp âCommandsâ 7.0.20196.12025
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoScript.rhp âRhinoScriptâ
C:\Program Files\Rhino 7 WIP\Plug-ins\RPC.rhp âRPCâ
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoBonusTools.rhp âRhino Bonus Toolsâ
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.0.20196.12025
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRender.rhp âLegacy Rhino Renderâ
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.0.20196.12025
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.0.20196.12025
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.0.20196.12025
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedPositions.rhp âNamed Positionâ
pascal
(Pascal Golay)
July 16, 2020, 9:11pm
6
Hello - can you please try running repair on both installations? Windows start menu > type Uninstall > click âAdd or remove programsâ > Find Rhino, click on it > choose 'Modify > Repair.
Any better?
taddvs
(Taddvs)
July 16, 2020, 10:43pm
7
Ran repair, 6 still didnât work.
Went back into safe mode, checked rhino render in plug-ins, closed and re-opened 6 and it works.
taddvs
(Taddvs)
July 17, 2020, 11:35pm
8
Rhino 6 seems to keep hanging on the same plugins. Disable in safe mode, open 6, re-enable and it will work for a bit.
RPC
Rhino Bonus Tools
Named Positions
Rhino Render
WIP opens fine with the same plugins enabled.
taddvs
(Taddvs)
July 22, 2020, 9:04pm
9
Figured it out. Nahimic was causing the issue installed with realtek audio drivers. Removed that and all problems went away
