After rending a file in Rhino Render the image appears normally. When zooming in or out on the rendered image, the repositioned image appears upside down and there is no way to return it to the upright orientation. This has occurred each time I tried zooming in or out and on multiple renderings. The image also flips upside down when doing as “Save As” and the saved file is upside down.
@andy is working on these flipped images
RH-49289 should be fixed in the last RhinoWIP. Please give it a try and let us know if its not working.
Hi, I’m new to Rhino, have version 7.
Have made fair progress but am now experiencing the upside down background image problem when I render preview or full render. Not sure what the ‘zoom’ advice means, have tried various ‘zooms’!
Can you help?
Thanks,
Lisa
Hi Lisa -
You are answering in a very old thread here and the problem is likely not the same.
Could you describe the issue in more detail? Which steps do I need to take to reproduce the problem? Can you provide a 3dm file and perhaps some screenshots?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
