I am having trouble merging 2 surfaces. I have a surface which is the layout of the car rim design, next I have a surface on a different layer with the holes cut out and made a surface out of this. I have tried a few different ways to either split, merge or drape over. Please let me know if you have any suggestions.
Hello - but for a given hole shape -is that the effect you are looking for? You can make them any shape you like, the solution will be about the same, I just want to know if I’m on the right track.
Ah. That adds some complication, to be sure. I was wondering if those were digitized curves. Well, obviously it is even harder without the thing to look at, but the curves tell me there is a deformed but more or less straight tube shape making the inner surface and then transitions surfaces out to the outer face and the inner surface, what ever that is. I’d build it that way if possible. Deternmine the shape if the inner ‘tube’ by digitizing around it.
Hello - I made the curves - the roundy ones, and lofted them together using the Loose style in the Loft dialog, then MatchSrfthe outer edge to the outer face, for curvature.
@cpduvern
Here’s another approach, more like what I described one post up - the transtions are a BlendSrf at the top and a FilletSrf at the bottom (to an arbitrary revolved inner face I made - it’s on its own layer). The upper transitions could be made in a variety of ways… I took the quick and dirty one by way of an example of how you might lay out the surfaces.
