Hi
In rhino 5 - rendered view, I can’t see shadows… at a different computer I was working at I had these dynamic shadows in rendered view, simultaneouly updating. I am missing that on this computer.
Windows 7 professional - 64 bit
Grafic card is: NVidia Quadro FX 3800
I’m using rhino 5 edu/ standard rhino render.
I updated to the newest driver version,but it has not changed anything.
I read the topics similar to my problem, but it did not help, that is why I am creating a new Topic.
hopefully there is someone out there helping me out.
I tried this: I deleted the rendered view from the display modes and restarted rhino. Then I created a simple plane with 4 boxes. Before deleting the rendered view it did not show shadows, after deleting it now shows the shadows. But only in this simple file. In my working file, which is has a file size of about 10 mb it still does not show the shadows. I upload 2 sreenshots.
I copied the geometry from the “bad file” into the “good file”, but there still it doesnt work. Probably not a problem with the file.
I created this file from I Autocad 3D File I received. I realized that the geometry is far away from 0,0,0 therefore I moved all geomtetry close to 0,0,0 now I can see shadows in rendered view, but they are not as good as in the simple test drawing. What else could be a problem? The geometry I took from the autocad file is mainly meshes. could that be a problem? I reduced the geometry in the file, removed all curves, but still have not the clear sharp shadows as in the test file
I tried and it improves the quality of the shadows. Many thanks.
Just one questions: why did I not had to adjust these settings in the test file with less and simple geometry? Do you know by any chance why?
phew, I am happy it works now… Was already worried, that a have a problem with the graphic card and already contacted dell customers support… can cancel that now
probably because of the size of the model. If your model is very large depending on the unit system used, the default shadow settings may need some tweaking.
There are several factors which can influence the appearance of realtime shadows and even geometry. The modelsize and filesize you´ve listed above should not be a problem if your display card is powerful enough. Your simpler example was maybe drawn close to the origin which is optimal. You can check your larger model and try to improve the display if you move it closer to the origin in case it is very far away from it.
Also take care of the “Camera Based Clipping Bubble” slider. Your model should fit in that bubble. Do not adjust it unnecessary larger than your model. If the shadow settings do not get you better results, it might help if you upload your model so it can be further inspected.
Hey, in my Rhino 5,0 64bit I have exactly the same problem and none of these solutions are working for me.
Furthermore Rhino 6.0 is also not working (Link) and cannot install Vray at all.
Is it a hardware problem, that is not possible to be solved?
