I have just download Rhino 7 for evaluation but I can’t use it at all. When I try to open a new or an existing file it just don’t open, it says at the top of the window “not responding”. I open it in safe mode to copy the system info:
I have allready download the latest nvidia, asus, and intel drivers but it didn’t work
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [0% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 12-4-2017 (M-D-Y). OpenGL Ver: (null)
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 12-4-2017
Driver Version: 23.21.13.8857
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 256 x 16843008
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21196.5001
I’m guessing you would get more help if you downloaded and installed the actual evaluation version, rather than some cracked version off the web. Anyway: your graphics card driver is more than 4 years old - I’m quite certain there’s a newer one out there.
-Jakob
It is the actual evaluation. I used to have the same problem with the Rhino version I’ve got when I bought the computer but I uninstall it because in this forum told me it was a cracked version and I download the evaluation. I recieved an email with a code license that says Ive got until Octuber 13 to use it. I can put the license code if it helps.
Anyways thanks for the help but if I understand, it is because of my nvidia graphic card? Im on a laptop so I don’t know if I can buy a new one.
With the correct Rhino version installed also ensure your driver is up to date. This one is 4 year old. At this moment of writing the current driver for your GPU is NVIDIA DRIVERS NVIDIA Studio Driver
To be honest I don’t know what is happening. I uninstall it once again and download the one I got from Rhino by email. In the email says that I need to put the license code that is on the email but when I open Rhino it crashed, I can’t even put the license code.
I run Rhino on safe mode once again to copy the system info of the evaluation copy but it has the same info I posted before… I uninstalled the cracked version, delete it, download the evaluation I received directly from Rhino… I don’t know why
Thanks for your reply. I put the System Info I get… once again I don’t know why I am getting this info if I allready uninstall the cracked version and download the evaluation directly from Rhino…
And I download the driver from the link you post… now it says the Driver Date is from 6-21-2021 but I still have the same problem. I can’t even put the license code I receive.
I swear I uninstall the previews version but I don’t know why it says I have a Corporate and not an evaluation version. In fact it appears the keyshot plug in I download before uninstall it.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 6-21-2021 (M-D-Y). OpenGL Ver: (null)
OpenGL Settings
Safe mode: On
Anti-alias mode: 4x
Driver Date: 6-21-2021
Driver Version: 30.0.14.7111
Z-Buffer depth: n/a
Hello - it appears that Rhino is stalling on opening a new file from template. Do you run the New command? If you just open Rhino with no commands, does it work?
Nope… It just remains the same. It says that is blocking a Keyshot plug in… but I don’t know why is trying to run the plugin if I just install Rhino. I don’t know if it is getting something from the previews version.
I put an Image from the mail I received from Rhino to download the evaluation version if it helps to prove Im running the one Rhino gave me.
Sounds like that crack has left some files behind that an uninstaller prolly wouldn’t pick up (being the cracker is not native rhino files so rhino uninstaller isn’t looking for them). Maybe each new rhino you install is trying to read these left over crack files but isn’t compatible, maybe causing a crash. Try finding those cracker files in your system and removing them. Good luck.
I called a friend and he helps me running the actual evaluation version. It seems you were right and in some way Rhino was reading some of the left over crack files; however I still can’t use Rhino. I have the same issue… I open Rhino but after a while it says “not responding” and I have to close the program.
I left the system info now that I am running the evaluation version.
OpenGL Settings
Safe mode: On
Anti-alias mode: 4x
Z-Buffer depth: n/a
