RH9 - BUG - Polyline "in-command" offset works strange
See gif below…
It’s looks like then command depend on curve angle…?
polyline
This looks really odd to me. I can see the offset lines jumping around while you draw and not stay parallel.
Can you save the file in that state, so that I can trace lines at the exact same position?
Unfortunately I can’t, I already deleted the file. However, when I tried to reproduce it today, Rhino keeps crashing repeatedly and throws an error dialog asking to submit a crash dump – I confirmed and sent the file.
It happens right when I use the polyline command, specify the “both sides” offset option; as soon as I draw it and finish the command, Rhino crashes…
