Hi all,
I’ve been staring at a script that gives me offset curves on both sides of closed polylines, but just cannot get this to work reliably. It’s based on Mitch’s script (thanks for sharing, Mitch!) from
https://discourse.mcneel.com/t/both-sides-offset-using-ironpython/27792/2
which I simplified a little bit, and added some debug output:
test_OffsetMulticrvs2SidesWEnds.py (2.2 KB)
So I have this Rhino model:
crv_offset.3dm (68.5 KB)
where the troublesome polyline is the red one. Running the script fails to offset. It only produces the 4 small segments, rather than 2 closed polylines.
When I run Explode, Join and SimplifyCrv in Rhino (green polyline), the script works. Automating this with the following RS script:
test_RebuildPlines.py (1.4 KB)
will create a nice, rebuilt pline, but again the offset script does not work.
Please note that offsetting in Rhino works in all 3 cases. Here are the object information, as output by List:
a) original polyline:
Rhino object: curve
DEVELOPER DEBUGGING INFORMATION ONLY
Use the Rhino “What” command.
layer index: 5
render material index: -1 (from layer)
ON_PolyCurve segment count = 11
Segment 1: (63.8746,65.2746)
ON_NurbsCurve dim = 3 is_rat = 0
order = 2 cv_count = 2
Knot Vector ( 2 knots )
index value mult delta
0 63.87464931716093 1
1 65.274613352306119 1 1.4
Control Points 2 non-rational points
index value
CV[ 0] (-13.061572574683822, 11.05095200562722, 11.524653923406049)
CV[ 1] (-13.202995391701705, 12.443754535246295, 11.524653923406049)
Segment 2: (65.2746,70.2407) gap = 0
0 65.274613352306119 1
1 70.240710811506062 1 4.966
b) re-built with RS script:
Rhino object: curve
layer index: 7
ON_PolylineCurve: domain = [95.812,127.749]
point[ 0] = (-4.5265288609232712, 1.6695930881383898, 0), 95.812
point[ 1] = (-4.6679516779411543, 3.0623956177574652, 0), 97.2119
point[ 2] = (-8.8464244950313642, 2.6381446411996645, 0), 102.178
point[ 3] = (-8.8265197546890377, 2.4389353514795058, 0), 109.354
point[ 4] = (-9.0061543652242122, 2.4206960533161119, 0), 116.405
point[ 5] = (-8.9496674831754959, 1.8643461119121181, 0), 117.03
point[ 6] = (-8.8694341040910913, 1.8724923038741164, 0), 117.111
point[ 7] = (-8.6876130084081424, 0.081729033627402359, 0), 118.911
point[ 8] = (-8.7678390209751811, 0.073583589596898591, 0), 118.992
point[ 9] = (-8.7031193679997401, -0.56377138661835069, 0), 121.568
point[10] = (-4.344688850237425, -0.12119837604532258, 0), 125.949
point[11] = (-4.5265288609232712, 1.6695930881383898, 0), 127.749
c) re-built in Rhino
Rhino object: curve
layer index: 2
ON_PolylineCurve: domain = [94.012,125.949]
point[ 0] = (-4.5657304788202069, -5.3752072433941045, 0), 94.012
point[ 1] = (-4.8889933065239362, -2.1916132495913168, 0), 97.2119
point[ 2] = (-9.0674661236141461, -2.6158642261491174, 0), 102.178
point[ 3] = (-9.0475613832718196, -2.8150735158692761, 0), 109.354
point[ 4] = (-9.2271959938069941, -2.83331281403267, 0), 116.405
point[ 5] = (-9.1707091117582777, -3.3896627554366638, 0), 117.03
point[ 6] = (-9.0904757326738732, -3.3815165634746656, 0), 117.111
point[ 7] = (-8.9086546369909243, -5.1722798337213796, 0), 118.911
point[ 8] = (-8.988880649557963, -5.1804252777518833, 0), 118.992
point[ 9] = (-8.9241609965825219, -5.8177802539671326, 0), 121.568
point[10] = (-4.5657304788202069, -5.3752072433941045, 0), 125.949
Does anybody have an ideas why this is happening, and how I can fix it?
Many thanks for your thoughts.
I’m on Rhino 5SR12 64-bit
