But, in some cases, when I rotate the solid, and than I try to align the gumball to the solid, it not do this.
I don’t understand, if there are somethings that I don’t know, of gumball.
Here there is one example Gumball.3dm (78.0 KB)
I try many times to align the gumball at the object ,and I see that the button “AlignGumballToObject” do the same relocation as “AlignGumballToCplane”
To align gumball to your object simply press and hold Ctrl button and then use rotation, translation or scale widget.
As you can see on the picture - I use gumball rotation widget while holding down Ctrl button, the rotation affects the gumball instead of object. You can do it with all directions and transformations. Good luck!
