Hello, if i create new hatch and set “solid gradient”, then will be created hatch with radial gradient - RH7 last release candidate.
Hello - the Solid gradient pattern is separate from the Solid gradient fill - I see this may get to be confusing pretty quickly - which are you referring to?
Hi Pascal,
thak you for reply.
Try it repeat:
1.Create rectangle and new hatch . In dialog window “Hatch” i choose Fill type as “Radial reflected” - OK
select this hatch and in properties was fill style “Radial reflected” - so many times, but now is ok…
Copy rectangle without hatch and create new hatch - In dialog window “Hatch” i choose Fill type as “Solid”
Select latest hatch and see properties in right container - here is still “Radial reflected”
