for some reason, when I use the hatch command, it always used the Radial Reflected as the default fill setting…not sure how I have I managed to save this as the default setting, but can I change it back to solid somehow?
thanks
Chris!
thanks
Chris!
Hm - I do not see that here - if you start a new, single session of Rhino and make a rectangle and a hatch, does this happen?
Hi - In a simple test here, it looks like this is remembered between sessions.
I started Rhino and made a hatch. It popped up with a solid hatch type. I changed it to radial and finished the command. Exited Rhino and restarted. Made a hatch and this time the radial type was active.
So, whatever type you used last time should be the type that the dialog starts with in a new session.
Awesome, thank you very much for that.
The key was to re-select radial reflected, accept it, and THEN go through the”process and select solid…
Sorted though, thank you again!
chris
