Revolve + Curve
Hi forum!
I’m trying to revolve while also following along a curve, but I can’t quite figure it out.
What I’d like to do is revolve the green shape in a circle, while at the same time following the curvature of the red one.
Any ideas on how to solve this?
I’ve attached a file as well.
Help.3dm (50.3 KB)
Help-4_02_tp.3dm (3.2 MB)
like this ?
if not - please sketch on the screenshot to make more clear what you re after.
kind regards -tom
Are you talking about something like this? Sounds like you need to redraw what constitutes the “profile” that is being revolved, which would involve splitting it in the z axis. (again I don’t know if this is exactly your goal.)
Exactly like that, thank you sooo much Tom!! :smiley:
What commands, or what order of commands, did you use so I can replicate this process myself for some tweaking?
_split the green base curve in half using option Point and midpoint snap
_join both parts of the curve
_extrudeCrv the red curve to be big enough
_circle draw an circle - you still find it on layer “guide” in my file
_project the circle to the extruded surface
finally:
_railrevolve the final surface, the green curve is the profile, the projected circle the rail - use the scale height = yes option
Amazing, you saved me days.
