I am trying to use the rail revolve command to make a 3D vase but the face keeps being 2D. How do I fix this?
Hi @taylorlautnerluv
Without seeing your input/curves, it’s impossible to tell where you go wrong. Post your file with the curves included, and I’m sure someone will be able to help you. Also, take a look at the small animation in Help for RailRevolve - it shows you how the curves should be set up correctly (Start the RailRevolve command and press F1 to go directly to the appropriate help file).
HTH, Jakob
