Revit Wall Cross-Section Parameter
Hello - I am using Revit 2021 and attempting to take advantage of slanted walls for the first time. I am having trouble altering this parameter using Rhino Inside Revit. The parameter seems to be calling for an integer, but I have not had any luck getting this integer input to update my Revit family. The end goal here is to make a variety of curtain walls that have different cross-section angles applied via Rhino Inside.
I’m not sure what changed, but this does appear to be working for me now. For anyone facing a similar problem, (1) will set the Cross-Section parameter to Vertical, and (0) will set to Slanted.
