Hello, I am trying to import families such as doors, windows and stuff from revit to VA via RevitToVA script, but not having success at all… When I hit the revittoVA button it shuts down the rhinoceros viewport and I cannot save the family as a VA object (that is my objective).
Hi @Leo13 , which Rhino and VisualARQ versions do yo have? also, make sure you have the latest Rhino.Inside Revit version. It should be at least the 1.26.
I am using Rhino 8.12, Visualarq 3.0.11 and rhino inside 1.26 and Revit 2024.3
I was able to import it to vissualarq by openning the grasshopper file and clicking on the buttons instead of just clicking on the button on the top of revit window.
But there is something that I would like to ask. When I import doors from the revit model, I am not being able to change the apperture in visualarq settings. Is it possible to achieve or the model imported from revit will be always static?
Try to update to VisualARQ 3.1 and see if the problem persists.
I could manage it, but there is something that I would like to ask. When I import doors from the revit model, I am not being able to change the apperture in visualarq settings. Is it possible to achieve or the model imported from revit will be always static?
Also, how I am able to kind of block edit a revittoVA family I imported. When I say blockedit I mean to edit it beyond the visualarq options, like the model features in rhino.
Now whenever I load VA3 it is showing me this:
And it crashes rhino whenever I try to access layer pannel, and some commands like push and pull… Please need help.
Now i cannot use rhino anymore when loading visualarq. I tried unninstalling rhino and VA but didn’t have success at all. Really need help in this.
error details, hidden for clarity
Object: Gh_param_ListTextOptions (level 1)
Exception has been thrown by the target of an invocation.
TargetInvocationException
Object: Gh_param_ListTextOptions (level 2)
The type initializer for ‘’ threw an exception.
TypeInitializationException
Object: Gh_param_ListTextOptions (level 3)
The type initializer for ‘A.cab3adf7976f072e569f2d20ea1b40b84’ threw an exception.
Object: Gh_param_ListTextOptions (level 4)
Could not load file or assembly ‘RhinoNestKernel&, Culture=neutral, PublicKeyToken=null’. Foi feita uma tentativa de se carregar um programa com um formato incorreto.
BadImageFormatException
Object: Gh_param_ListTextOptions (level 5)
Bad IL format.
Object: gh_nesting (level 1)
Object: gh_nesting (level 2)
Object: gh_nesting (level 3)
Object: gh_nesting (level 4)
Object: gh_nesting (level 5)
Bad IL format.
Object: Gh_param_GlobalNestingCriterion (level 1)
Object: Gh_param_GlobalNestingCriterion (level 2)
Object: Gh_param_GlobalNestingCriterion (level 3)
Object: Gh_param_GlobalNestingCriterion (level 4)
Object: Gh_param_GlobalNestingCriterion (level 5)
Bad IL format.
Object: gh_RhinoNestObjecCreator (level 1)
Object: gh_RhinoNestObjecCreator (level 2)
Object: gh_RhinoNestObjecCreator (level 3)
Object: gh_RhinoNestObjecCreator (level 4)
Object: gh_RhinoNestObjecCreator (level 5)
Bad IL format.
Object: gh_param_ObjectOrientation (level 1)
Object: gh_param_ObjectOrientation (level 2)
Object: gh_param_ObjectOrientation (level 3)
Object: gh_param_ObjectOrientation (level 4)
Object: gh_param_ObjectOrientation (level 5)
Bad IL format.
Object: gh_param_ObjectCriterion (level 1)
Object: gh_param_ObjectCriterion (level 2)
Object: gh_param_ObjectCriterion (level 3)
Object: gh_param_ObjectCriterion (level 4)
Object: gh_param_ObjectCriterion (level 5)
Bad IL format.
Object: gh_param_nesting_parameters (level 1)
Object: gh_param_nesting_parameters (level 2)
Object: gh_param_nesting_parameters (level 3)
Object: gh_param_nesting_parameters (level 4)
Object: gh_param_nesting_parameters (level 5)
Bad IL format.
Object: gh_nesting_parameters (level 1)
Object: gh_nesting_parameters (level 2)
Object: gh_nesting_parameters (level 3)
Object: gh_nesting_parameters (level 4)
Object: gh_nesting_parameters (level 5)
Bad IL format.
Object: Gh_remap (level 1)
Object: Gh_remap (level 2)
Object: Gh_remap (level 3)
Object: Gh_remap (level 4)
Object: Gh_remap (level 5)
Bad IL format.
Hi @Leo13 I assume this issue is resolved, according to your comments here: Fatal error after Visual Arq in RhinoInsideRevit - #10 by Leo13
