VisualARQ Revit import error
Hi, I am setting up Rhino.Inside Revit for the first time and want leverage VisualARQ and Land Designs too. I also got the Objects not Recognized error. So I imported a 3DM file directly and can now see an object in the Revit 3D view. When I move that object Revit hangs and a Not Responding error occurs making editing impossible.
My first experience with this set up has been very disappointing. Is there any fix or should just do 100% of the model in Rhino and the rest in Revit for documentation, with no change to the model?
You can see the Plugins did load (at least the Toolbars have):
I’m using Rhino 8 / Revit 25
Any update?
Hi @Warren2 the current version of Lands Design 6.2 is not working with Rhino.Inside. We are investigating what’s happening. I’ll get back to you when we figure it out. On the other hand, VisualARQ 3 should work fine. Try to disable Lands Design to test the Rhino Inside with VisualARQ workflow.
@fsalla Ok.
