Revit "Roof by Face" from "Trimmed Surface"
I’m trying to create a Roof from trimmed surfaces using Rhino.Inside. Is there a component, or set of components for doing this natively? Or is there a work around similar to this forum post below?
Thanks,
Hi @j.cole,
Since in your case all the faces are planar you can join your top surfaces into a Brep and run something like this.
The benefit is that the resulting Roof will be editable in Revit and as a single Roof element.
RiR-PlanarFacesRoof.gh (12.8 KB)
Amazing, thank you for the help!
