Retrieve Values from Text Fields
May I check if there is a way to copy texts without copying the text fields?
This means copying the text would “retrieve” the values in the text fields, and the pasted text would just contain the values itself. Or perhaps is there a command to ‘explode’ the text fields?
Here is a screenshot of an example below:
The use case for this is when I am copying this text into another document, or just to be able to copy the values as text.
How about the ConvertTextToBlockAttribute ?
Hi @jessesn,
That works fine. Hope there will be a less roundabout way to do this in the future. Thank you!
Hi Type0 -
I’ve added that request to the list as RH-89678 Clipboard: Add Text Content
RH-89678 is fixed in Rhino WIP
