I want to automate a function with the button editor.
Therefore the result of e.g. command _Area is to be copied to the clipboard.
Then the value is to be inserted into the text field at the command _Text.
Thanks for your help.
But it does not copy the contents of the results row.
Also the Rhino command “_paste” does not help.
I think “_paste” is not executed within the running command “_text”.
I can press ctrl+V to insert the results.
This is then the result which is inserted:
A long time ago I created complex Marcos in Excel.
There you could read out certain characters of a “string”
Counting from the right or left ( e.g. right 17,23)
Does this also work here?
Then you could extract only the number up to three places behind the comma.
That the result would look like this:
750.826
Thank you very much for your help.
Happy Regards
Ralf
