Retrieve the Indices with the Highest Number
Hello all, I need some help with retrieving the indices with the highest data. Indices highlighted with blue should be retrieve while maintaining the indices. These should be retrieved automatically; indices should not be manually inputted.
output should be a list of 12,13,14,15,18
Aidea.gh (11.9 KB)
  1. Open a python component
  2. Use the following code:
inds = [index for index, item in enumerate(x) if item == max(x)]
a = inds
Whereby x is the name of the place you connect your list (remember to swap to list input and float)
It’s cleaner on your file. Enjoy.
Hi it worked, thank you!
thank you!
Hi! how can i retrieved the item with the highest value without sorting the list?
Fastest with bounds
Aidea2.gh (10.0 KB)
