Is there a command/button to reset the cplane to its viewport defaults?
I have an alias Previous CPlane and can switch back but sometimes it doesn’t work. Such a command would be very handy. Thank you.
_CPlane _Undo (don’t know why it’s called Undo actually, Previous made more sense to me)
Hmm, should normally work - Do you have a repeatable example? Remember, it is relative to the viewport where the change was made, it needs to have the same viewport active when you run it.
Ok will introspect. Thanks for your advice!
Hi Hannes , Four viewport hit 2 times resets the default cplanes. Correct? Mark
You can make keyboard macro: CPlane > World > Top. For example: Ctrl+Alt+Home = '_CPlane _World _Top
I think @markintheozarks has the best solution.
Run the 4View command, then ZEA.
I like the Idea of Andrew as it won’t reset the view just the Cplane put it on HOME. Works perfectly. What is John what is ZEA?
@John_Brock
“ZEA” is a default alias for Zoom Extents All"
Type it and see.
Thank you John!
I don’t know how many times Mitch has typed that one in on this forum.—-Mark
