To be able to disconnect all planes and scale the distorted ones to planes again. As you see the Gumball is out of sync to the overall geometry. Thank you. Not sure whether this is the right way to place feature requests.
can you please post a file with steps to try to reproduce?
Is the “Set CPlane by 3points” what you’re looking for?
The gumball will follow the new Cplane you create, so you can move and strech based on the new plane, instead of the “World Top”
World Top Cplane, gumball aligned to the default XYZ axis
New Cplane aligned to the 3 points you set as the Origin, X and Y axis
Step #7 is optional; you can give a name to the new Cplane.
