Request for Osnap EXTRAs to be in two columns like the primary
Request for Osnap secondary EXTRAs to be put in 2 columns like the primary Osnap.
When you have large buttons in the left Sidebar in 4 columns (to stick to the new logical setup where many things are in pairs) you will automatically get the Onsnaps in two columns with icon and text, but the secondary Osnaps (EXTRA) with Shift and Ctrl will still display in on column and therefore the Osnap Container takes up to much space IMO.
Sorry for the poor soundquality.
The issue that’s happening is the text length values of the shift states are much longer and the layout for them requires wider buttons which forces the layout to a single column. Example “PerpFrom” is pushing the layout requirement in your example. I’ve played with abbreviated versions but localization might still mess that strategy up as well. Icon only mode can solve this currently. Have you tried that layout?
@Trav - Hi All. There are multiple issues in the lauch edition of Rhino 9 including some issues which has been working very nicely in WIP and BETA but appears to be lost in the launch edition.
I have made two short video demonstrating a couple of the issues related to Toolbars with large buttons and especially the combination of Images (Icons) and Text in Floating and Top/Button and Side (Panels). Hope that some of these issues can be solved in the SR0 before 24. November?
Hi Tim,
OSnaps have their own UI settings found in the Options > Advanced panel by searching OSnap. They are not linked to the command toolbar settings.
You can also run the TestOSnapToggles command which will give you the same options found in the advanced settings in the command line.
Icon only mode is going to be the way to keep your rows and columns from changing since it keeps everything the same size, no matter what the state is. The columns shift when the text gets too wide for the layout. This is why it changes when you press shift. The words cant fit onto the button in multi-column.
Fantastic. Thanks. And I can even get my checkbix back :slight_smile:
woohoo! Glad that helped!
