Working on creating 3D Print layer texture. Right now I, all in Rhino, I contour the shape, then either apply pipe or sweep profile, But When I use multi-pipe it will skip rows opr create half pipes, so I can only select a few contours at a time…
any suggestions on how to automate this using Grasshopper? It doesn’t need to be this process shapes => Contour => Pipe … it just needs the texture, possibly applied directly to a surface?
Thank you in advance
3DP rep.3dm (14.6 MB)
