Replicate GH's Display in Rhino Viewport?
I wonder what setting do I need to change in my Shaded Display mode to match my GH preview identically. The colors are much more vivid and nicer when displayed through GH preview and when I bake to Rhino they are dull.
GH Display Shapes.gh (21.3 KB)
Display Shapes.3dm (1.0 MB)
I was able to get something close, but not exact with a little tweaking… Setting the transparency per object like you did in the example file is certainly not the way to do it… It would require you do that for every object new and old… The best way is to tweak a customized material for all objects within the display mode…then also try tweaking the ambient light setting.
GH-Sim.ini (14.8 KB)
Hi Jeff, thanks for the reply and the file, I will try it!
The objects were baked from Grasshopper with the script attached which automatically assigns transparency and color to each objects so that wouldn’t be a problem.
In the end what I need is the shaded mode to work as GH preview mode.
This way any color at any transparency will display the same way.
But similar is good enough does not need to be exact! Thank you!
