Replace a section of 3D mesh
I have this 3D mesh:
Versace model
I intend to replace the face of the above 3D model with the face from the following 3D mesh:
3D face
The 1st 3D model is substantially larger than the 2nd 3D face.
Question
I don’t have much experience with Rhino3D and I’m confused what’s the workflow. Can anyone help? Some hints about the workflow.
I uploaded my 3D meshes here: https://drive.google.com/file/d/1Is-KzRBrPE9ldHXPc_ung3qCIJQDMIMQ/view?usp=sharing
Scale the 2nd face to the same of the 1st face.Draw curve to the outside of the 1 st face then use mesh boolean split command and adjust it and then join it.
Would be a lot easier if you found a coin shape without a face already on it - there must surely be something like that on the internet. Or do you absolutely need to use that base shape?
@ftzuk You’re right. I intend it to be a Versace 3D model. I couldn’t find a Versace 3D model without a face so far.
https://drive.google.com/drive/folders/1PnI0e95Ee6u_icByPfZ9J6mnbQ7igTa9?usp=sharing
@ftzuk Looks great. Thanks. Can I get to know your exact workflow and the tools you used?
I don’t work with meshes often so just used Shrinkwrap to close it - there’s other ways to close it but I wanted to get this done quick. Maybe someone else can advise on best way to close the mesh without needing to shrinkwrap.
