I am using raytraced mode and capturing viewport to file. The settings I have are 8in x 12in at 300 dpi with 2000 passes and the cycles are set to 0 ms throttle. I have been watching the GPU usage and the CPU usage with task manager and both are fine. The GPU uses less than 10% utilization and the CPU uses less than 30% utilization. My computer specs are as follows:
CPU - Intel i7
GPU - UHD Graphics 630 and NVIDEA GeForce GTX 1060
The rendering takes a while but I’m wondering if there is a way to use more power for the render, whether it’s in the settings somewhere in Rhino or if it would be something else.
