I am making a lot of different parts in plywood and am quite new to Rhino. They are all out of a similar material to baltic birch. Is there an easy way to have the look of ply end grain applied to the edges in a solid. Below is pictured a part and then the texture i want applied to all sides?
- Create new PBR material with the texture in the base color slot.
- Sub-object select the sides (cmd+shift+click).
- Assign material to the selection.
- Create a box mapping on your object
- Ensure box encompasses your object
- No to Capped since you use only sides
- Drill into endgrain texture and rotate 90 degrees if necessary
Thanks so much. Ill give that a shot
