I want the horizon line to be moved to the bottom of this drawing so does that require just a simple plane to be built on the back?
I want to have a ground plane reflection without the environment reflection but reflection of the objects, I noticed it is possible if I don’t set an HDRI but I need the HDRI to have a realistic reflection on the metal parts of my objects; is this possible?
Hello - The horizon line will depend upon the camera viewing angle and elevation… You can set a reflective environment separately from the lighting one in the Rendering panel, but if your reflective objects depend on a relatively active environment then that might not help. Post a simple file if you like.
Model KD200.3dm (10.3 MB)
Its like setting the ground plane with the reflection makes it choose. Because when I opened the file this morning to work on it only the object had the decals and not the reflection.
Don’t mean to be super annoying,
Ive been a rhino user since 2012 and had heavily used solidworks at my last job but at my new gig im using rhino and I am trying to create really great images for a product catalog and clients.
