Hi there,
Something has changed about my views, I have tried to reset everything to default but nothing happened.
Rendered view is too dark (see pictures before and after), and shaded view does not have any colors.
This is what the rendered view looks like now:
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [13% battery remaining]
Secondary graphics devices.
NVIDIA GeForce GTX 1060 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 6-24-2018 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 6-24-2018
Driver Version: 24.21.13.9836
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 6 GB
Hi -
Thanks for that information.
There are several things worth noting in that report:
and
Basically, you are running your PC without any display hardware. The GeForce GTX should be the primary OpenGL device on your system and should definitely be used.
Since this was previously working fine on your system, it is possible that a Windows update messed with the drivers and you should make sure to check if there are any pending updates for Windows and reboot the machine.
The drivers for both the GTX and the UHD Graphics are old. Check the Notifications panel in Rhino for links to the sites where you can find updated drivers.
