I have an object which are part of a building I am supposed to make for a class. They are all extruded surfaces and for some reason whenever I work with them, it slows my computer down to the max and it will not go to shaded or rendered, always switching back to wireframe. I just bought this new computer and I am not sure why it is not working. Here is the system info command.
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Evaluation, build 2021-09-13
License details: Cloud Zoo
Expires on: 2021-11-23
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [75% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-24-2021 (M-D-Y).
Primary OpenGL: NVIDIA T500 (NVidia) Memory: 4GB, Driver date: 7-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.41
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2021
Driver Version: 30.0.14.7141
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Hi Luiza -
If you start a new file from a factory-default template and just create a simple box, will that let you display it in the Shaded display mode?
In your building file, when you put a viewport into the Shaded display mode, is anything printed to the command line - please use F2 and copy the text that is printed to the command line.
Yes, Just a simple box will work, but not the actual object I want rendered does.
when I put it into shaded display it says “creating meshes… press esc to cancel” and it always takes incredibly long so I end up pressing it. And then it says “Render meshing failed or was canceled. Switching to wireframe display.” in the command history.
Command: _Open
Name of the file to open ( UpdatePromptUpdateBlocks=Yes Browse ): “C:\Users\serra\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave\sitemapforlars.3dm”
Loading Legacy Rhino Render, version 1.50, Sep 13 2021, 19:32:50
Successfully read file “C:\Users\serra\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave\sitemapforlars.3dm”
Command: _Rectangle
First corner of rectangle ( 3Point Vertical Center AroundCurve Rounded )
Other corner or length ( 3Point Rounded )
Command: _Rectangle
1 closed curve added to selection.
Command: _Delete
Command: _Rectangle
Other corner or length ( 3Point Rounded ): 120
Width. Press Enter to use length ( Rounded )
Press Control to extrude, tap Alt to make a duplicate
Command: _Undo
Undoing Gumball rotate
Command: Move
Point to move from ( Normal Vertical )
Point to move to
Command: '_CopyToClipboard
Command: '_Paste
Command: Move
Point to move to <84’10-1/4">
Command: ‘_Paste
Command: Move
Point to move to <60’-0">
Command: '_Paste
Command: Move
Point to move to <20’2">
Command: PlanarSrf
Command: PlanarSrf
Command: PlanarSrf
Command: PlanarSrf
Command: '_SetDisplayMode
Select a display mode ( Viewport=Active Mode=Wireframe ): _Viewport=_Active
Select a display mode ( Viewport=Active Mode=Wireframe ): _Mode=_Shaded
Display mode set to “Shaded”.
Creating meshes… Press Esc to cancel
1 open surface added to selection.
Command: _Delete
Command: _Undo
Undoing Delete
Command: _Rectangle
Command: _Rectangle
Command: _Rectangle
Command: '_Paste
Press Shift to 3D scale, press Control to extrude, tap Alt to make a duplicate
Command: _Delete
Command: ‘_Paste
Command: Move
Point to move to <20’4">
Command: Move
Point to move to <160’-0">
Command: PlanarSrf
Command: _Undo
Undoing GumballTransform
Command: PlanarSrf
Command: PlanarSrf
1 closed polysurface added to selection.
Command: _-Sun
Choose sun option ( ShowPanel=No Options ): _ShowPanel
ShowPanel ( Yes No Toggle ): _Toggle
Choose sun option ( ShowPanel=Yes Options ): _Enter
Select a display mode ( Viewport=Active Mode=Shaded ): _Viewport=_Active
Select a display mode ( Viewport=Active Mode=Shaded ): _Mode=_Rendered
Display mode set to “Rendered”.
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Isometric
View point ( NE NW SE SW ZoomExtents=Yes ): _NW
Command: _Isometric
View point ( NE NW SE SW ZoomExtents=Yes ): _NE
14 curves, 4 surfaces, 9 polysurfaces added to selection.
Command: Make2D
Time to Make2D was 0.73 seconds
Command: ‘_CopyToClipboard
Command: ‘_Paste
Command: Move
Point to move to <1’-0">
Command: Move
Point to move to <70’-0">
86 curves added to selection.
109 curves added to selection.
Command: _Delete
Command: _Isometric
14 curves, 4 surfaces, 10 polysurfaces added to selection.
Command: Make2D
Time to Make2D was 0.69 seconds
Select a display mode ( Viewport=Active Mode=Wireframe ): _Mode=_Rendered
Command: _Isometric
Command: _-Sun
Choose sun option ( ShowPanel=No Options DateAndTime Location ): _ShowPanel
Choose sun option ( ShowPanel=Yes Options DateAndTime Location ): _Enter
Command: _Delete
Command: _Delete
Command: _Undo
Undoing Delete
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Isometric
Command: _Isometric
Command: ScreenCaptureToFile
Command: ViewCaptureToFile
The Jpeg format does not support transparency. Set to Png format
Image successfully saved as C:\Users\serra\AppData\Local\Temp\realsundiagramforlars.png
Image successfully saved as C:\Users\serra\Downloads\realrealsundiagramforlars.png
Command: _Delete
Autosaving file as C:\Users\serra\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave\sitemapforlars (67298) RhinoAutosave.3dm
Autosave succeeded
Command: _Delete
Command: _Delete
Command: _Delete
Command: _Undo
Undoing Delete
Command: _Undo
Undoing Delete
Command: _Undo
Undoing Delete
Command: _Undo
Undoing Delete
Command: _Open
File successfully saved as C:\Users\serra\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave\sitemapforlars.3dm.
Read 1 annotation style that references 1 font that is not installed on this device.
Annotation style referencing a missing font:
Millimeter Small / Helvetica Neue Regular
Missing font:
Successfully read file “C:\Users\serra\Downloads\the four g spine roses.3dm”
Command: _Open
Command: _CommandHistory
Hello- please try SelBadObjects Does that select anything, if so, hide or delete those objects and see if it works.
If there are no bad objects selected, I would try turning off layers , half at a time, to see if you can isolate the layer that has the problematic objects.
