Strange behaviours with simple copy objects in Render viewstyle
Hi Again.
recently I’ve been experiencing this veeery strange behaviour in Rhino Rendered Viewstyle.. an unintended trasparency that is radomly assigned to objects and that is impossible to get rid off. .. it only happens in Rendered Viewstyle.. but all the other Viewstyls render correctly the geometry (no transparency)..
ODDITY IN RENDER VIEW.3dm (96.2 KB)
Rhino 8 SR19 2025-4-22 (Rhino 8, 8.19.25112.13001, Git hash:master @ 0fe5f551e3e34ca51834ba0ca2217647d8027942)
License type: Educational, build 2025-04-22
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: AMD Radeon™ 780M (AMD) Memory: 1GB, Driver date: 6-27-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\mutar\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.6.4.0\bella_rhino.rhp “Bella” 24.6.4.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.19.25112.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.19.25112.13001
Disable all of these, then restart Rhino and load the file you attached. Do you still have the transparent cube? If not, then re-enable each plug-in in turn, restart Rhino and see if the cube is turning transparent. If it does you know which plug-in it is and you can tell so in a reply.
I have none of these plug-ins, I don’t see a transparent cube when opening your file.
No successs..
I disabled the plugins, restarte rhino.. new file.. and still getting this oddity..
Any other suggestions?
well the mistake seems to be corrected now when I re-enabled the plugins… so the “solution”.. disable and enable again… (only disable was not working)… I’ll post again if I get this oddity
best
