Render resolution custom entries
Hello Team,
there is the dropdown in the render panel from where one of the preset resolutions can be picked.
I never use any of these resolutions. The aspect ratio I use is almost always 3:2, so I have to set a custom resolution via the text input fields. However, putting in a custom resolution and then locking it via the checkbox does not work. It will always reset either x or y to some value that makes the aspect ratio fit that of the viewport. Though this bug can be fixed, I would like to know if there can be more improvements made to make life a bit easier for those who frequently use certain resolutions that aren’t part of the presets in the dropdown.
I hope there is a simple solution like adding own custom resolutions to a textfile somewhere in the installation folders?
Adding your custom resolutions via a text file is exactly what you can do:
Check under Preset Sizes.
Perfect, thank you very much!
Looks like this was possible for a long time already? How could I have missed this. Anyway, works fine. My custom resolutions are all listed together at the top of the dropdown list - it’s perfect like that. Would they have been mixed in by resolution size, it would have been less quick to choose from for me.
Any idea how to do this on Mac rhino? the Docs only explain on how to on Windows.
the app folder looks like this on Mac:
thanks a lot
Akash
It seems there is currently no way to do that on Mac
RH-77313 Add custom size presets to render resolutions for Mac users
