Please help, I cannot render on Rhino 7
Hi Does anyone knows how to fix this? I’m using Rhino 7 on Windows 11 and I’ve tried so many times to render but it just keeps stopping and saying that it is ready at a random number and sometimes even stop at 1 sample when it should be like 500 or 1500 (just like in the pictures below) but it works fine before I updated to Windows 11 so I’m not sure what could be the problem
thanks in advance!
Hi -
Have you looked at the Rhino Render Advanced Settings section a bit further down in the Rendering panel to make sure that you are not overriding the production render quality?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Evaluation, build 2022-02-08
License details: Cloud Zoo
Expires on: 2022-05-24
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 15Gb)
Computer platform: LAPTOP - Plugged in [42% battery remaining]
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 6-17-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 2-10-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-10-2022
Driver Version: 30.0.15.1179
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.15.22039.13001
I’m finding the same thing. I think there’s a problem with the Rhino Render Plugin that is set as the default. If I change back to the Legacy Rhino Render everything seems to work correctly. Perhaps McNeel could offer some advice here?
Please run _SystemInfo and copy&paste the results unabridged here.
