Render Mesh looks strange, does not follow internal edges
In the attached you find a conic propeller hub with trims to fit the propeller blades. The render mesh of this is quite wrong. If you Untrim and keep the trim curves, the re-trim with them, the same ugly mesh is obtained. What can be done here?
RenderMeshProblem.3dm (237.9 KB)
Hi @menno
I don’t know how (or why) you got the two caps and cylinder merged (perhaps using MergeSrf), but use DivideAlongCreases to turn it into a “conventional” polysurface with actual edges - that’ll give you a much nicer mesh.
HTH, Jakob
Ah, yes. I have CreaseSplitting disabled - for good other reasons, but here it bites me.
Sorry, could’nt resist :wink:
Hey Menno,
I had a good laugh seeing you post Rhino memes.
't moet niet gekker worden…
:wink:
