Render for Rhino Mac
Run the _DocumentProperties command and select the “Rhino Render” tab. From there you can adjust the image size and antialiasing values (a higher value results in greater smoothing). You can also go to the “Mesh” tab and select the “Smooth & Slower” or “Custom” Render Mesh Quality if needing more control. Then run the _Render command to view the result and save out as an image file.
