Render colors on Mac
This is a problem that I’ve just noticed in the last wip 8 release.
In the rhino edit window set to RENDER I pick my colors just like forever. When I switch to RAYTRACED the color also look OK. But when I do a full RAYTRACED render some of the colors switch colors completely. I hope you can see the attached pic.
I have a MacBook Pro M1 Max with 64GB memory.
Thanks for any help.
I’m seeing the same issue – screenshots of viewport raytrace vs. render
test file:
thanks for reporting, I can reproduce this. It looks like the red and blue channels are mixed up.
RH-76784 Blue and Red channels are mixed up
I’ll check later but I believe the final SAVED render will be in the original colors. It’s just the render/raytraced window that’s incorrect.
I checked it. The final SAVED retrace is the correct colors.
good to know!
RH-76784 is fixed in the latest WIP
