Nearly every time, i try to rename a layer in rhino, the cursor jumps from the layer panel into the commandline and tries to interprete the text as a command.
Sometimes i have to try several times to rename a layer, until the name is accepted successfully.
thank You for Your tip!
I think I’ve solved the problem now.
I use to work on an wacom-tablet wich works fine inside rhino.
If the cursor is exactly over the text to be edited, it works fine.
But if I move the cursor only a little bit outside the text, it jumps into the commandline.
I didn’t realize this yet.
I think this problem will occur only to me (and very few other users of wacoms) and not in case if one uses a common mouse.
