Windows Rhino 8 - in the layer panel, there is a glitch that does not allow me to move the cursor location using the keyboard arrows to navigate forward and back of the layer name when trying to change a layer name. Instead it jumps out of the name text and starts navigating the layers themselves. I do this quite often so it’s a bit of an issue.
Hello- As far as I can see this works in the current builds here. That is, left and right arrow keys navigate within the test I am editing, up and dowm jumps to the layer level and moves through those.
I have the same problem. When editing my layer names in the new Rhino 8 I cannot use my left arrow key to move my cursor backwards in the text. When I do so it navigates away from the layer name I wanted to edit.
Which is unfortunate because when I use the F2 shortcut to edit names the cursor lands at the end of the layer name, forcing me to use my mouse when I didn’t have to make the extra clicks before.
I would like to be able to use my left and right buttons to move the cursor in the text.
Hi Justin -
That seems to work fine here. Please run the Rhino SystemInfo
command and copy-paste the result here.
Editing the name of a child layer, left arrow jumps to the parent layer.
System Info
Rhino 8 SR4 2024-1-23 (Rhino 8, 8.4.24023.15001, Git hash:master @ e0f90d20c78f2125a0ec9cfffc9d9decbc052c01)
License type: Kommerziell, build 2024-01-23
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.15
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-1-2023
Driver Version: 31.0.15.3799
Z-Buffer depth: 24 bits
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24023.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24023.15001
Thanks.
It looks like we have this on the list: RH-70731 Layer: left arrow exits naming sublayer
