Could you help me please? Is is possible to use custom name for branches I would like to select the branches {1} {2} ect. in panel by selection own names "type of steel L profile, for example {1} to L25x25x5, {2} to L35x35x6 ect.
Thank you for advice
you can’t change the path of a branch into a custom text, but you can recall a specific path with custom names using something like this
consider you can also create a parallel data tree with one item per branch, and that item is the custom name you wanted to set to that branch
You can also filter your geometry with user text data.
