Hi all, i looked all over the forum but have not found if there is a way to split a data tree or list an item by its name rather than index? For example I would like to select the Planar curve from the data tree below not by saying {0} [0] but by saying Planar. Is there a way to do this? Thanks.
ah thank you, I tried something like that but couldn’t fugure out how to apply the pattern to the match text tool. Would you mind taking a look at this one too? It is related and is been sitting for a few days without a solution. Curves change order along a slider I am sure there is a way to fix it. Thanks again regardless!
