Could you help me please?
Is it possible to rename branches to values name as shown on scheme.
Since {0} to {20}, {1} to {25} and {2} to {33}
Thanks for advice
Best regards
Olek
Thanks for advice
Best regards
Olek
It is ok but this leads to a problem with conversation from parth to curve since the initial data is curves
@PetrVacek code would work, as your naming the paths, so the data your using in those paths in your case curves, his example numbers will remain unchanged.
Its also possible to do this with the Parameter view like so.
Tree statistics component is also a super useful component to know about also mind yo as it also gives you branch lengths and total number of branches.
Rename Paths.gh (12.8 KB)
