Removing Points/Open Curves/Overlaps Before Sending To Vcarve For 2D Cut
Issue with multiple points populating on a single intersection for reasons unknown. Having same issue with multiple curves stacked on each other, even curves I am sure I only drew once.
I’ve tried all the commands I can find for locating open curves, etc. and can’t find a path that identifies these occurrences. All files are 2D Files.
In AutoCad I would use the Auto Constrain command to locate issues within the file before exporting to cut software. It would locate every occurrence when this command was used.
Open to any suggestion at all.
Thanks in advance!!!
Hi Steve -
Please post a 3dm file with a few curves that show what you are looking at.
To select open curves, use the SelOpenCrv command. What does the “etc” in that sentence refer to? Which commands have you tried?
There isn’t enough information in your post to be able to provide much help, I’m afraid.
Sounds like this might be another occurrence of this?
