Remove edge without deleting vertices
In rhino SUBD iss there a way to delete an edge without deleting its vertices like we can in maya ?
can you show a use case example for that?
@serasu_abac If you are trying to do the same as in your other topic (Subd Lost Faces), I think _Stitch is the command you are looking for. You can use it to create geoemtry between two SubDs, or fusing edges when both vertices selected are the ends of one same edge.
