Relocate Gumball not working
Short bug report:
After I completed the “Relocate Gumball” command, the gumball first appear in the correct (new) location. After deselecting and selecting again, the gumball shows up in the old position.
best, Frank
Hi Frank - this is the expected behavior for multiple selections, control points, or groups (=multiple selection). Is that the case here?
Hi Pascal,
Yes, that was the case here.
If this in intentional, I will try to group my selection first.
Thanks,
Frank
Hi Frank, it’s not so much intentional as unavoidable… it’s a limitation that is not possible, currently, to work around, so I’m told.
Grouping is not going to help - that is simply a multiple selection.
The workaround is to use Block first to block the selections. The relocated gumball will then remember it’s location. Explode will free the objects from the block. HTH
