Is it possible to change the layer color of a SubD created with Reflect?
What is “Reflect”? Do you have a sample model you can share?
– Dale
This is a "! This is the result of executing the “_Reflect” Command.
Is the inverted Objcect on the right a so-called “undecided” object?
I thought that the layer color on the right side could not be changed.
I’d like to complete this as a single object with “! _Reflect _Pause _RemoveExistingSymmetry” Command?
best
Also, as you may have already figured out, there are some parts that have not been translated into Japanese.
Thank you very much.
Hi Kyle,
Reflect or symmetry,
is this s Sub-D exclusive function?
Or can we use it on Surfaces/Curves as well?
subd only
