should redo be on shift-command-Z instead of command-Y?
another keyboard related thing…
the delete key doesn’t seem to be recognized (if trying to delete a component)…
if you go Edit menu-> Delete
it does work.
fn-delete seems to be the temporary workaround until the keyboard standards are fully up to date.
good find. thanks
This is being discussed here. I think how it will go is that we’ll port all of the functionality, and see how to deal with input paradigms between platforms when the codebase syncs up with GH2, but @david, @dan, @marlin, and @curtisw would be able to comment more precisely.
another one along these lines… (not sure if each instance needs pointed out individually or if there’s a general keystroke fix that will remap everything)
Adding to selection of grasshopper modules works ‘right’ as it’s a left-mouse + shift key…
deselecting an individual item is weird by requiring the control key… to keep consistency with rhino’s deselect, it should probably be the command key instead.
That’s from windows input logic and I see that it wasn’t on @dan’s list from the link above. Added to that. …
