Is it possible to rebuild the wireframe of a surface so the spacing will be even when seen from the top view? Is this possible in Rhino or Grasshopper? Just to clarify, I don’t need the spacing to be even in absolute values, say the length of a curve subdivided into equal parts, but for the spacing to be even in the XY axis, see example in red
Hello - if you Contour the surface in two directions at the XY spacing you like, then DupEdge, you should be able to combine all of those curves in a NetworkSrf and get the isos spaced as you like. I am not sure the surface will be a shape that you like, on the other hand.
I think that if I get the wireframe to be devided evenly in the xy axis, that can help me generate a recursive pattern in grasshopper based on the elevation of a terrain. Don’t know if this would be the right approach
the U and V degrees are currently 3 and 3. I think uploading the surface is kind of irrelevant in this case, I just did as an example, since what I want is to apply this to multiple topographies. Any network surface should do as example
how does the degree of the U&V affect this exactly?
