Is there a command to rebuild a curve and repair geometry?
As you see the curve creates no proper results during pipe command.
Same applies for imported curves from Illustrator that seem to work as I would delete some corner points for further use.
Maybe there is also another approach in repairing a curve. As sometimes the curve would work making a planar surface but sometimes not and the curve would properly lay on one construction plane and would be closed - but it work as a splitting curve for a planar surface.
So maybe there is some indicator tool to at least analyze the curve for the errors.
Thank you
