Rearrange layers by dragging
Hi there,
Currently, it seems that the only way to move layers is by dragging child layers into parent layers, or using the arrows in the layer panel to move the layer/sublayers.
Is it possible to move layers by dragging them between others like below?
In this image, I’m dragging layer 3 between layer 2 and layer 1.
-Jeremy
Hi there,
Rearranging layers within Rhino is a common task, and learning from other software, I believe it would be beneficial to be able to drag 1 or more layers within the layer list. When dragging, the user may benefit from being able to drag between layers with the help of a highlight line.
Here is an example in Photoshop with layers and groups
In rhino, one can’t drag between layers. Using the up and down arrows is less intuitive and slower for me.
Best,
Jeremy
Hi Jeremy -
This is from the Rhino 8 WIP:
2023-03-03 Move layer
Ah thanks Wim, just tested in 8 WIP and it’s working nicely, however there seems to be 1 issue.
If there are more layers in the list requiring the scrollbar to be moved, the dragging doesn’t seem to activate the scroll. This is either with 1 layer or multiple layers selected.
Whereas in Rhino 7, it does activate the scroll
To make the scroll activation even better, perhaps there could be some acceleration/non-linear dragging activated scrolling? Or perhaps the user could change how fast the scroll works when they’re dragging the layers.
In the past, I’ve had projects with hundreds of layers and nests, and managing these becomes very tricky. Dragging one parent layer from the bottom of the list to the top can take a long time.
-Jeremy
I see this, thanks.
RH-73413 Layers: Scroll the list on drag and drop
RH-73413 is fixed in the latest WIP
This is my first time commenting so please forgive me if I’m commenting on a wrong thread or something but does anyone know if this issue has been fixed in Windows Rhino 7?
What’s confusing about all of this is that I don’t have this issue with Mac Rhino 7, just Windows Rhino 7.
Hi Jon -
RH-73413 was fixed in Rhino 8, not in Rhino 7.
Rhino 7 for Windows is quite a bit different from Rhino 7 for macOS. For Rhino 8, this difference is a lot smaller.
