Read Revit workplanes into grasshopper
is there a chance to read the existing workplanes from revit into grasshopper?
many thanks!
Can you clarify a bit more on what you are trying to read from Revit…
By work plane you mean reference plane? or levels? or the active work plane in the view?
If you mean Ref planes then below should work for you
Hello Mohamed,
sorry for using the misleading wording… The first part of Your definition did not work; I think it’s because I use the german revit version. After internalizing the category of one existing reference plane it worked perfectly.
Thanks a lot!
